Up Topic Welding Industry / Technical Discussions / Fillet weld must have back purge in stainless steel?
- - By crashproj (*) Date 06-25-2009 09:54
Greetings....!
Guys here's the new issue, we are doing a socket weld, reinforcement pad and support pad but they require us to back purge for this... are you guys really doin this kind of stuff...
cheers,
Parent - - By Shane Feder (****) Date 06-25-2009 12:41
Crashproj,
What are you actually asking ?
"are you guys really doin this kind of stuff..."
"Us guys" generally follow the clients specifications, the codes / standards and good work practices.
A good welder can usually weld a fillet weld (eg. reinforcing pad) on the outside of a stainless pipe without causing oxidation on the inside of a pipe.
A less competent welder may weld too hot and cause oxidation.
Cheers,
Shane
Parent - - By 803056 (*****) Date 06-25-2009 20:22
The thickness of the pipe wall and the welding process (heat input) will influence the maximum temperature attained on the pipe ID. Temperatures above 400 degrees F will typically result in some level of discoloration.
Whether the discoloration is unacceptable is determined by the customer and what is specified in the project specification.
Parent - By crashproj (*) Date 06-25-2009 20:48
Al,
I agree with you Al.. when heat input is the one will influence the discoloration and not the purging gas.
thanks and regards,
Parent - By crashproj (*) Date 06-25-2009 20:31
shane sorry...
What i mean , is it necessary to have a back purge when welding on stainless pipe with a fillet weld?
"A good welder can usually weld a fillet weld (eg. reinforcing pad) on the outside of a stainless pipe without causing oxidation on the inside of a pipe."
So it is not mandatory to have a back purge on a fillet weld, actually the thickness of the run pipe is 7.9 mm same thickness for the reinforcement pad we completed 2 spools without back purging and no oxidation on the inside of a pipe.
regards
