We've qualified a PQR with a 1" Type II plate. We did CVN testing at -40 Degrees F. The WPS supported by this PQR has a groove thickness range of 1/8' thru Unlimited when no CVN requirements are invoked. When CVN is invoked the qualified thickness range is 5/8" thru Unlimited. The test was done in the 1G position. Does the 5/8" minimum thickness still apply to 1F fillet welds when CVN is a requirement?
Again, another gray zoooone!!
Thanks,
Skerfan GBR
