Up Topic Welding Industry / Inspection & Qualification / saw wire to flux ratio
- - By Nanjing Date 07-01-2009 12:07
I am looking for a quick answer from experienced SAW hands-on welding guys especially. When welding with 4.8mm carbon manganese wire at around 700 amps how much flux do I need? Say for a 25kg reel of wire how much flux (in weight) will I need? I know used flux can be sieved, reused and mixed with new flux but the bottom line is has anyone ever worked out, say for a ton of wire, how much flux is required? Some companies will shovel up it up the floor and re-use it without mixing it without new flux.
Parent - By js55 (*****) Date 07-01-2009 13:15
It depends on how efficient your flux recovery is.
I usually start at a 2:1 flux weight to wire weight ratio when purchasing.
Shoveling off the floor is a clear no, no. And if you don't keep mixing in new with recovery you will increase fines and the flux burden, usually manifest by small often almost horizontal porosity.
Parent - - By CHGuilford (****) Date 07-03-2009 16:28
I always estimate a pound of wire to a pound of flux to start out.
Yes, you can do better than that by using a flux recovery system - and we have one. But there are countless "little things" that happen to make your flux usage vary to a level higher that you planned for - wastage, contamination, etc.
Parent - - By weldktm Date 06-12-2013 13:14
Relating to the reuse of the flux you could have a look in this link:
http://www.weldinguide.com/viewtopic.php?f=5&t=80
Parent - By Shane Feder (****) Date 06-12-2013 22:03
I think the OP was looking for a "quick answer".
Responding 6 years later is pretty much a waste of time.
Regards,
Shane
