Thanks for your reply but, you said you're using sandpaper? could you please elaborate because, sandpaper is a BIG TIME NO - NO!!! Especially with Ti...
Another potential problem may just be the type of acetone you are using... Can you tell us what is the exact type of acetone you are using?
You do not need to use a vacuum chamber with a laser (Electron Beam would usually require a vacuum), you just need to make sure that the atmosphere is as oxygen free as possible (less than 10 ppm or less would be suitable), and with a totally inert atmosphere - Argon. What type of laser system are you using? I hope it's not a Carbon Dioxide system. ;)
To answer your next to last question... Yes it is! The source(s) of oxygen being introduced into the weld that's causing the oxidation is what you should be eliminating because, there are a number of possibilities for contaminating the metal surfaces... One must backtrace step by step such as controlling the amount of oxygen within the atmosphere by checking the ppm's of oxygen prior to welding, to using the correct type of acetone when cleaning the surfaces, to making sure one does NOT USE SANDPAPER to remove any surface oxides that may or may not be present on ALL of the surfaces that make up the joint.
Btw, what grade of stainless steel are you using?
Also, is the stainless steel being prepared in the same manner as the Ti? If it is, then you need to adjust your metal preparation whereby both "MEMBERS" of the joint are given the same upgraded treatment in order to insure that oxygen is not being introduced into the weld from either metal, from the shielding as well as the backing or trailing gas, from the use of "SANDPAPER?", or from the use of an incorrect type of cleaning agent. Nine out of ten times the reason why Ti welds are contaminated is because of not adapting to demanding that it is of the utmost priority to clean, clean, clean in the proper manner, and to control the amount of oxygen down to less than 10 ppm, or less.
This link may be of some use for you:
http://eagar.mit.edu/3.37/H-337-39.pdfThese two may also be helpful:
http://eagar.mit.edu/3.37/H-3371-18.pdfhttp://eagar.mit.edu/3.37/H-3371-19.pdfSo, get rid of the sandpaper, and use something ("scotchbrite" pads from 3M) that will not leave any residual loose sand grains, or inadvertently impregnate the surfaces with whatever is in the sandpaper...
If you are using acetone, make darn sure you use a reagent grade of acetone ,and not the stuff that comes out of 55 gallon drums because if you do use a non-reagent grade of acetone... You end up degreasing the members with grease!!! pardon the pun but, the non-reagent grade has oil in it, and hydrocarbons even from one's fingernail left on the surface of Ti is enough to cause porosity, oxidation, and yes brittleness in the weld.
