From what I see these guys doing, they are using an exothermic tube and oxygen rather than a steel tube, electricity and oxygen.
The tube burns to make the pre-heat, and the oxygen does the work. Most likely the tube is made from materials giving a thermite reaction, they are claming 8,000 degrees, that is hot.
