I recently became involve in qualifying aluminum extrusions WPS for a new project.
Since this company already has been fabricating similar products for several years, I thought I’d review the existing qualified WPS’s to get a heads up, this where things start to get beyond me and have me feeling uncertain. I found qualification for 3/8” plate bevel groove, this is ok so far. The product is an extrusion where the material transitions from heavy (3/8”) to thin (0.085”) and the qualification range of the WPS only allows down to 1/8”. They are welding the whole extrusion bevel-groove on the heavy and square-groove on the thin with the hot parameters as used for the heavy. The method I found being used to prevent the 1-1/8” length of 0.085” from being blown away was to place a piece of brass or bronze as TM- removable backing at the thin section.
So I thought that since there is no-way that they would be able to sustain the parameter for the entire length o the AWS D1.2 figure 4.20 -20” test coupon, that maybe I could justify the existing procedure by macro-etching a cross section of the existing 1-1/8” length. The thought behind this is to not slow down production by having to requalify new parameters for the 0.085” portion of the extrusion weldment.
Any ideas?
The new extrusion is 1/8" to 0.85", and I qualify new WPS for this.
