Up Topic Welding Industry / General Welding Discussion / Hot root
- - By LongArc (**) Date 07-11-2009 22:48
    I do my roots on pipe 70-95 amps, depending on the gap. I've seen guys do it around 100 on 2 1/2 inch pipe with a large gap. Ive heard its done with allot of drag and punchinthe sides on the root, is this true?
Josh
Parent - - By jeff parker (**) Date 07-13-2009 20:12 Edited 07-13-2009 20:32
yea you can if you can control the arc but be carefull or you will undercut the root and/or suck out the root. but now you need to realize that every machine runs different so those numbers on a machine are useless, learn to just pay attention to the way the puddle is flowing.
Parent - By bigrod (**) Date 07-14-2009 03:42
what size rod are you using for your root?  the majority of the time i just use 3/32 on 2"-4" at about 25-30 amps
