Up Topic Welding Industry / Technical Discussions / 310ss to A36 mild
- - By jim parker (**) Date 07-17-2009 13:28
Im looking to run .045 fluxcore wire. Is 309 the proper wire to join 310ss to A36 mild?
Parent - By js55 (*****) Date 07-17-2009 18:20
309 is a good choice.
Parent - - By jeff parker (**) Date 07-22-2009 17:45
yea jim 309 is the right joice for stainless to carbon
Parent - - By cfrancis (**) Date 07-23-2009 13:57
Yes,,it's the right choice... Also,certain weld joint configs can have cracking issues that I have encountered in the past. When tested, the centerlined cracked welds had extremely low Ferrite levels(less than 3). I ended up solving that issue by welding with ER-312, which yields very high Ferrite levels. (20-30) and took the cracking issue away.  So, just in case you mayencounter some centerline cracking,,that may be an idea for you as well.
Parent - By js55 (*****) Date 07-23-2009 14:42
312 can be a very good choice, but keep in mind that 312 is essentially a duplex stainless steel and is therefore more readily subject to sigma phase formation if the service temp is high enough.
