Up Topic Welding Industry / Technical Discussions / Welding T-1
- - By jarcher (**) Date 07-20-2009 02:08 Edited 07-21-2009 22:51
I told someone a few months back that there was a Mittal steel pamphlet on the welding of T-1 (A514, A517) Steels that had the best information on welding T-1 I had ever seen collected in one place. Unfortunately Mittal was bought out by Acelor and the link was no longer operative. So, as I promised, I found my copy and digitized it and placed it on my webserver at:
http://factionists.net/Download/Welding%T-1%Steel.pdf
There it will stay unless I get a copyright complaint from AcelorMittal.
Edit: Grammar
Parent - - By welderbrent (*****) Date 07-20-2009 21:37
Thanks jarcher,
I don't use it as much as I used to, but on a casual scan there appears to be very good info there.
Have a Great Day,  Brent
Parent - - By eekpod (****) Date 07-21-2009 10:36
I really like the way they explain the heat input formula, and then reverse engineer it to figure out the amps.  That should help a couple of guys in my shop.
Parent - By jarcher (**) Date 07-21-2009 22:48
Glad to be of some service.
Parent - - By Brian T. Beard (**) Date 08-16-2009 11:38
Thanks for the info. I weld T-1 quite a bit and have been asked many questions by companies and have had nothing in writing to go by. So again I thank you.
Parent - By ssbn727 (*****) Date 08-16-2009 19:37
Here's an article one may find of interest from the Fabricator also:
http://www.thefabricator.com/ArcWelding/ArcWelding_Article.cfm?ID=1636
