Up Topic American Welding Society Services / Certifications / Bridge Performance Qual
- - By js55 (*****) Date 07-20-2009 20:03
Help me out here folks. What is the most common performance qual being spec'd for bridge work under D1.5.
I am interested mostly in that which is being specified for fabrication as opposed to field work.
Parent - - By GRoberts (***) Date 07-20-2009 23:52
In order to cover 80-90% of the work in a shop I recently worked for, we did a 3G FCAW (that would cover F, H, V-which I don't necessarily agree with), and a 1G semi-automatic SAW.  About 10% of the welders would also take a 4G test.
Parent - - By js55 (*****) Date 07-21-2009 12:29
Greg,
I don't have a D1.5 available. Would the test coupons be consistent with Fig 4.21 or 4.30 in D1.1?
Parent - - By GRoberts (***) Date 07-25-2009 21:38
We did unlimited thickness, so that would be fig 4.21.  We also did RT so that they could be used for fracture critical work.
Parent - - By js55 (*****) Date 07-27-2009 12:22
thanks
Parent - - By 803056 (*****) Date 07-27-2009 14:05
The performance tests are essentially the same as those in D1.1, but the use of power tools for interpass cleaning is prohibited. If I remember correctly the use of hand tools for improving bead profile is all prohibited in the most recent edition of D1.5.
The most common tests I give are the standbys, 3G and 4G on 1 inch plate.
Parent - - By js55 (*****) Date 07-27-2009 15:14
thanks Al
Parent - By 803056 (*****) Date 07-27-2009 20:53
My pleasure.
