I bought this welder in unknown condition and have found it has a bad pc timer board. I have wired the thing up and it will turn on and when flipped to "stick" mode the contactor in it will pull up and it will make a low hum but will only burn an 1/8" rod when set at maximum. It has a couple plug ins on it and when I plugged a flood light in it worked fine. I believe the problem that made the board go bad is between the transformer and the board itself. Ive decided to just try and sell it to someone who might need it for parts or can fix it. Im not very good with electronics. I have all the sheet metal for it in good condition. The machine looks like it spent most of its life in a factory. $150 obo
http://i858.photobucket.com/albums/ab149/HarlanGraves/DSCI0212.jpghttp://i858.photobucket.com/albums/ab149/HarlanGraves/DSCI0211.jpg
