Up Topic Welding Industry / General Welding Discussion / ESAB OR LINCOLN?
- By dschlotz (***) Date 08-08-2009 13:36
Esab Coreshield 8 or Lincoln NR 233 in 1/16"?  Both are E71 T-8 and are acceptable for the project they are intended to be used on. Best would be based on ease of use and appearance. I've  asked around our shop and the consensus is about 50/50. Management (non-welders) tell me that I made a mistake by having a test plate run with 233 because ESAB Cor8 is the better wire. What do you guys think?
Dennis
