Up Topic American Welding Society Services / Certifications / Charpy v-notch test
- - By alan domagala (**) Date 08-13-2009 01:09
This may have an obvious answer to some people, but why is a charpy v-notch test required when both the steel manufacturer and the filler metal manufacturer already perform them? I think I understand the fundamentals of this test but it seems redundant. Thank you.
Parent - - By waccobird (****) Date 08-13-2009 12:56
If you are typing of Qualification of process, then think about, when welding heat is used and if not correctly changes the structures of those materials from their tested state into another, the Charpy tests help to determine your procedure's compliance to Code and the ability of you procedure to develop the correct properties.
Hope this has helped more than hurt.
Parent - By alan domagala (**) Date 08-13-2009 20:03
Yes, thats basically what I was thinking. Thank you.
