AWS D1.1 has the same requirement for ASTM A514 and A517 (QT)steels, see section 6.11. But AWS seems to take a different approach on highly restrained joints to avoid cold cracking, 1) heat-affected zone hardness control and 2) hydrogen control. See Annex XI in AWS D1.1. They are mainly using preheat to avoid cracking and give recommendations for low, medium and high restraint.
From a practical point of view there would be an advantage in delaying inspection if delayed cracking is of concern. So even if the welding code does not address the delayed inspection, your contract specification could and should address your concern.
