Up Topic Welding Industry / Technical Discussions / The German lloyd welding procedure
- - By doreme Date 03-29-2002 08:47
I have a qusetion to write the welding procedure for German lloyd.
but I don't know the mean of the weld factor term.
Anybody can tell me what is the meaning for the weld factor for the German lloyd standard of welding procedure sheet.
thanks
Parent - By CHGuilford (****) Date 03-29-2002 17:13
I just did a search of "weld factor" on google.com and had some interesting results. I'm not going to describe them here because I can see there is quite a bit to the subject and I'm sure I'd end up misquoting. However, you might try it yourself and see if it helps.
CHGuilford
