Up Topic Welding Industry / Technical Discussions / API 1104 Heavy Glass
- - By DAYANARA (**) Date 08-23-2009 23:36
Dear All
I like your comment about API 1104 - 7.7  Cleaning Between Beads, I not understand definition of Heavy Glass, because I from Peru.
I like example about Heavy Glass.
Thanks.
Dayanara
Parent - By Arctic 510 (**) Date 08-24-2009 00:32
Dayanara-
I believe this refers to the glass-like deposits that sometimes can form on welds.  Given the context of 7.7 (cleaning), I can't see any other meaning.  I have seen this on many GMAW welds, a semiautomatic process (and 7.7 is refering to semi automatic/mechanized welding).
Maybe one of the good people on the forum can post up some pictures of examples, as I have none.
Parent - - By aevald (*****) Date 08-24-2009 00:40 Edited 08-24-2009 01:48
Hello DAYANARA, I believe this might help to somewhat explain about the "glass" that you had questions about. Best regards, Allan
EDIT: I couldn't attach the PDF it was too large so I'll try a link.  http://www.scsprocess.net/library.data_/Sept07SCSUPDATE-Hi-Res.pdf
Parent - - By ssbn727 (*****) Date 08-24-2009 07:40 Edited 08-24-2009 07:56
And just to add to Allan's excellent example of what is meant when the term "Glass" is used to describe silicon formations of varying sizes, shape and lengths on the the weld deposits... I would like to include this link for anyone to have an understanding about just what the SCS process (Smooth Clean Surface) is in relation to steelmaking:
http://www.scsprocess.com/
http://www.scsprocess.com/scsprocess/howscsworks.html
Also, if anyone wants to review some in depth info on SCS, here's some more links:
http://www.scsprocess.com/resources/infodownloads.html
http://www.scsprocess.com/resources/videos.html
Finally, here's a link which briefly describes some disadvantages and limitations of SCS as well as another method of steelmaking surface prep technology that overcomes some of the mentioned limitations:
http://www.scsprocess.com/usesavings/otheruses.html
Enjoy the read! ;)
Parent - - By aevald (*****) Date 08-24-2009 07:48
Hello Henry, I hadn't even heard of this before looking for some examples of "glass" on the net. Interesting stuff, thanks for including those links. Best regards, Allan
Parent - By ssbn727 (*****) Date 08-24-2009 08:01
You are very "weldcome" Allan!!! ;)
Glad to be of service! :) Btw, now that you mentioned it, I think I'll post these links in the Metallurgy section also... Always a pleasure Allan! :) :) :)
Parent - By DaveBoyer (*****) Date 08-25-2009 03:20
Those must be some really agressive brushes.
Parent - - By Arctic 510 (**) Date 08-24-2009 18:33
aevald-
Thanks for posting the link!  A picture is worth a thousand words!
Parent - - By aevald (*****) Date 08-24-2009 21:02
Hello arctic510, you are certainly welcome, besides, I get to learn something all the time when I participate. Best regards, Allan
Parent - By Russo Date 08-25-2009 09:56
Thank you for the discussion. I am really glad to read this discussion.
Teeth whitening
Parent - By DAYANARA (**) Date 08-27-2009 02:19
Thank you Allan
I understad your example.
Dayanara
