Up Topic Welding Industry / Technical Discussions / AISC main member tracability standard?
- - By david bean (**) Date 08-28-2009 16:19
AISC Main Member Tracability Standard; is this a real standard? I would like to  think so but i can't seem to find it anywhere!!! it is recommended from one of my municipalities, but i cant seem to find it anywhere!!!
Any Recommendations???
Parent - - By waccobird (****) Date 08-28-2009 16:28
2.1.1. What is required for the identification of material?
Identification means the ability to determine that the specified material grade and size is being used. An identification system is required in the 2005 AISC Specification Section M5.5: "The fabricator shall be able to demonstrate by a written procedure and by actual practice a method of material application and identification, visible at least through the "fit-up" operation, for the main structural elements of each shipping piece.
last modified 1 January 2006
2.1.2. What is the difference between traceability and identification of material?
Traceability means the ability to identify a specific piece of steel in a structure, throughout the life of the structure, and its specific Mill Test Report [MTR]. As such, traceability requirements are significantly more expensive than the identification requirements in 2.1.1. The owner should clearly understand the differences, limitations, and relative costs involved.
Traceability is not a requirement in the AISC Specification and, when required, must be clearly specified in the contract documents prior to the ordering of material. The following elements of traceability should be selected only as needed:
1. Lot traceability vs. piece-mark traceability vs. piece traceability: Lot traceability means that the materials used in a given project can be traced to the set of MTR’s for that project. Piece-mark traceability means that the heat number can be correlated for each piece mark, of which there can be many individual pieces. Piece traceability means that the heat number can be correlated for each piece, which effectively demand separate piece marks for each piece.
Each of these three successive levels of traceability adds significant costs. Piece traceability, the most expensive option, is necessary only in critical applications, such as the construction of a nuclear power facility. Piece-mark traceability is often specified for main members in bridges. Lot identification is most common in other applications where traceability is required.
2. Main-material traceability vs. all-material traceability: Main-material traceability means that beams, columns, braces, and other main structural members are traced as specified above. All-material traceability means that connection and detail materials are also traced as specified above.
All-material traceability, the more expensive option, is necessary only in critical applications, such as the construction of a nuclear power facility. In other cases, main-material traceability is sufficient, when traceability is a requirement.
3. Consumables traceability means that lot numbers for consumables such as bolts, welding electrodes, and paint can be traced. This is necessary only in critical applications, such as the construction of a nuclear power facility.
4. Required record retention defines the level of detail required in documenting traceability (who, what, when, where, how, etc.).
5. Fool-proof record retention vs. fraud-proof record retention: Fool-proof record retention means internal verification of records. Fraud-proof record retention means external certification of records. Fraud-proof record retention is necessary only in critical applications, such as the construction of a nuclear power facility. In other cases, foolproof record retention is sufficient, when traceability is a requirement.
2.1.3. How does a fabricator maintain traceability, when it is required?
Each heat of steel produced by the mill is tested for chemical content and mechanical properties and the results are recorded on a MTR, which is provided to and maintained in the records of the fabricator. Each piece that is rolled from this heat is then labeled with an identification mark that relates to the corresponding MTR. The fabricator applies an identification mark to each piece. Because this piece mark remains with the piece throughout the fabrication and erection process, the material is traceable back to the MTR for that individual piece.
Many connecting elements and similar fittings are too small to accommodate the marks to identify the piece from which they were cut. Additionally, such items are commonly made from stock materials with marks that may have inadvertently been abraded or lost during years of storage. In such cases, the fabricator provides written certification that the stock material meets the contract requirements.
Manufacturers of consumables such as bolts, welding electrodes and paint provide documentation as to the content and specification compliance of their products. This documentation is provided to and maintained in the records of the fabricator. The packaging in which the products are shipped is referenced to this documentation.
In some cases, the fabricator may purchase materials through a steel service center. When this is the case, the steel service center must transmit the necessary documentation from the manufacturer to the fabricator.
Hope this Helps more than it Hurts
Parent - By swnorris (****) Date 08-30-2009 00:35
AISC Main Member Tracability Standard............
David, is this how it was worded in your job specs?
Parent - By ziggy (**) Date 09-08-2009 01:27
David
Many project specifications (i.e. Division 5) will reference the AISC Code of Standard Practice (COSP). You can obtain a free download at
http://www.aisc.org/store/p-1784-code-of-standard-practice-for-steel-buildings-and-bridges-march.aspx
Take a look at Section 6.1 Identification of Material. There are three options available for the fabricator to identify material. The most common and normally accepted form is noted in 6.1.1 (a).
The COSP is a must read code for all structural steel fabricators. Several shops make it mandatory reading for their project managers with outstanding results for the fabricator.
Hope this helps some,
ziggy
