Up Topic American Welding Society Services / AWS Learning & Education / sensitivity contrast and density
- - By hrezvany (*) Date 08-31-2009 11:10
what's real definition of sensitivity, contrast and density in RT approach?
Parent - - By spots (**) Date 08-31-2009 14:09 Edited 08-31-2009 17:39
Sensitivity in an RT image is demonstrated by the image quality indicator (IQI) I am familiar with wire type and hole type. The specifications of the code or your client will tell you what hole or wire must be visible in the image. IQIs come in a large variety of materials and sizes depending on how thick/dense your subject material is.
I am not sure what usage contrast has in your context. I have only seen that term used in applications where there is a difference in thickness in your image. In that case the definition would be much the same as contrast in your television how much difference there is between light and dark.
Density in lay terms is how dark or light the image is. There is a required darkness (density) of the base metal so that the light and dark spots in the weld or area of interest can be interpreted with some idea of what they mean. If an image is too dark or too light indications will be missed.
Parent - - By hrezvany (*) Date 09-01-2009 06:08
are these relationship true or not?
kv increase            density increase
kv increase            sensitivity decrese
kv increase            contrast decrease
contrast incrase     sensitivity increase
density increase     sensitivity decrease
Parent - - By 3.2 Inspector (***) Date 09-01-2009 07:44 Edited 09-01-2009 12:36
Before attending to the CSWIP course you are required to have prior knowledge.
3.2
Parent - - By hrezvany (*) Date 09-01-2009 10:04
what do you mean?
Parent - By 3.2 Inspector (***) Date 09-01-2009 10:26
Atleast you figured out how to use the rating system :)
Parent - - By jwright650 (*****) Date 09-01-2009 11:26
>you are required to have prior knowledge or atleast know how to read a book
C'mon man...is that really neccessary?
Parent - - By 3.2 Inspector (***) Date 09-01-2009 12:36
no
Parent - By hrezvany (*) Date 09-05-2009 10:06
Don't interrupt discussions, and try to be helpful for yorself and others please!
