I believe that I agree with the book, but a without a whole lot of context, it is hard to know for sure. I think they are saying that a large root pass (i.e. high heat input) will reduce overall shrinkage. (Although I don't know how you can get shrinkage without distortion. Perhaps it is just a funny way to differentiate between angular distortion and longitudinal or transverse distortion). The root pass does have the most affect on the total amount of shrinkage/distortion as compared to other passes. However, whether it is the root pass or any other pass, the heat input correlates (i.e. higher heat input passes/larger passes) to the amount of stiffness provided to the joint by the weld metal in order to resist distortion/shrinkage on subsequent passes.
