Up Topic Welders and Inspectors / Welding Equipment Classifieds / armature
- - By tompit9 (***) Date 09-05-2009 19:23 Edited 09-05-2009 22:24
is there anyone near boyd(ft.worth) area that might have armature for a '68 sa200 they want to get rid of? i will try to get the length of it posted in a bit.
*main armature*
Parent - - By shorthood2006 (****) Date 09-05-2009 23:08
tom, their is a guy on here that is from dallas that has armitures....i think his handle is fixalinc or maybe weldersales
Parent - - By tompit9 (***) Date 09-05-2009 23:37
those armatures run in different lenghts dont they?
Parent - By shorthood2006 (****) Date 09-06-2009 00:56
yes, shorthoods and later models are different
Parent - By FixaLinc (****) Date 09-06-2009 05:09
Try Larry Buross at Applied Equipment in Dallas he goes by weldersales on here.  His email is weldersales@alrmail.net   Might also try P.A Ross Machinery in Dallas  http://www.parossmachinery.com/
Parent - - By tompit9 (***) Date 09-06-2009 14:43
the armature that I have removed is rite at 33" long when flat on the ground.
Parent - - By shorthood2006 (****) Date 09-06-2009 18:47
is yours burned up?
Parent - By tompit9 (***) Date 09-06-2009 18:53
yes sir
Parent - - By tentenforum Date 09-19-2009 07:34
as far as i know, they run on different length...
Directors Liquidation Advice
Parent - By hondakitty2 (*) Date 10-15-2009 13:24
Call Weldmart 800-460-6474-they do the best job of rewinding. they give a 5-year warranty! Can't get that on new anything from Lincoln. They seem to know welding machines very well-they helped me with my Harbor freight plasma and my airco dip-Pak. My local Air Gas treated me like I had AIDS!
Parent - - By raftergwelding (*****) Date 10-16-2009 03:00
Hey tom find an arm. Yet i can get u 1 used but its in pleasanton
Parent - - By tompit9 (***) Date 11-20-2009 17:46
how much for the armature Shad? cheap!!!!!hahaha
Parent - - By raftergwelding (*****) Date 11-21-2009 03:32
ill have to call and ask i dont have 1 did you find 1 yet
Parent - - By tompit9 (***) Date 11-21-2009 23:51
yea i got 1 and had it tested and it was shorted
Parent - By raftergwelding (*****) Date 11-22-2009 15:59
logan got ahold of me after he read your post he is trying to call you so he can make it right call him hes a good guy he'll make it right with you let me know the last time i called my guy about an arm a used 1 was 800
