Up Topic Welding Industry / General Welding Discussion / coils
- - By tompit9 (***) Date 09-06-2009 19:23
what is the proper way to check the coils in the housing of my sa200?(Continuity) i should check continuity and should get a reading i suppose if i don't get reading then that means there is a break in the wire some where rite?
Parent - - By Cumminsguy71 (*****) Date 09-07-2009 15:29
Do a search on here I know Kaye has posted it here before, I've seen it. Wait a minute....might be in my mail...nope, nothing in there about testing the coils.
Parent - - By Regmanager (**) Date 09-08-2009 12:34
Are you talking about the ohm reading of the shunt fields? If that is what you are asking they should read 40 ohms disconnected.
Parent - - By Cumminsguy71 (*****) Date 09-08-2009 13:10
I think that's what he is talking about
Parent - By raftergwelding (*****) Date 09-08-2009 17:34
the coils he is referringtocould be the field coils whcich are locatedon eachside ofthe exciter and yesthey have to be disconnectedto check them. but i dont remeber the reading you are suppose to get
Parent - By raftergwelding (*****) Date 09-08-2009 17:35
gimmie a call when you get time and i'll walkyou thru it after i figure out what you are trying to check
