Assistance with a weld symbol from an assembly drawing for a large ship unloader fabricated in Norway would be appreciated.
The weld symbol indicates a double fillet weld at a corner joint where two 10mm thick plates meet in a tee shape. The leg size for both welds is listed as "a5". I presume the number 5 indicates 5mm, but I do not know the significance of the lower-case letter "a" preceeding the 5 in "a5". Other fillet weld symbols on this drawing also have the letter "a" preceeding the number, such as "a3" and "a6".
Thanks, Jim
