Hi Zeek!
When you mention "Butt joint" could you tell us in greater detail the joint configuration?
Also what are your procedures for preparing/cleaning the Aluminum prior to welding and are you making sure that the seamer is indeed as clean as it should be???
What size filler diameter and grade/brand of filler wire are you using?
Finally, are all of the orifices in the seamer for the backing gas and are they checked periodically for any obstructions?
