Weldcome to the forum - stick around, participate and you will most likely have a good time here :)
You did not mention any code of construction, which makes it harder for people to help you.
Before answering your question, I would like to ask you a few questions;
- What is the design code/standard?
- Any specific client specs in regards to welding?
- What is a PID inspector? is it just a misspelling for a PED NoBo? Usually PID refer to a diagram which shows instruments and valves...
- What is a JCC card?
I will however make an attempt on answering your question- without knowing the facts, so use my answer with precaution.
The wps on a welders certificate has nothing to do with production welding. A welder gets certified by welding a test to a certain wps (any wps within range) if the welder pass the test, it shows that he is able to follow a wps and make a sound weld within the acceptance standard. You dont need to use the wps used for certification in production, no inspector can force you to do that - unless it's written in the spec.
Did you hire the new welder as a new employee or did you hire the company he works for as a subcontractor?
In case you hired him as a direct emplyee, your company needs to qualify him, as it is you who are responsible for his welds.
In theory you can use any wps when you qualify a welder as you are testing his abillity to follow the said wps.
You can submit as many (qualified) wps as you want, it often proves (atleast in my book) that you are serious about your welding.
I often see some wps' with a HUGE range of diameter/thickness and amperage, it might be within range of code, but a welder can only move his hand at a certain speed.
Whenever I make a procedure test I always advice the client to have multople wps' made, remember, a wps is meant to be a tool for the welder.
3.2
