Up Topic American Welding Society Services / Technical Standards & Publications / Electrode storage oven - SS and Lo-Hi
- - By ziggy (**) Date 09-16-2009 23:59
Is there a code requirement for storing stainless electrodes in an oven?
I have seen 316L and other SS side by side with Lo-Hi electrodes in electrode storage ovens, but my experience with SS is limited.
If there is a code requirement, what is the code?
Thanks,
ziggy
Parent - - By 3.2 Inspector (***) Date 09-17-2009 13:36
You will get the best answer from the electrode companyas many codes refers to their specifications.
3.2
Parent - By 803056 (*****) Date 09-17-2009 19:24
AWS D1.6 requires the stainless SMAW electrode to be stored in a holding oven like those used with low hydrogen type carbon steel covered electrodes.
The covering used for the EXXX-15 electrode is similar to that used for E7018, i.e., they use a limestone based flux covering that tends to be hygroscopic.
I would not like to see carbon steel covered electrodes stored with stainless steel electrodes due to the probability there will be a mix-up sooner or later when the welder draws the electrode from the oven.
