Hey Kix!
GOOD LUCK!!! :) :) :) "Let er fly boys and girls." WTF???
Minimize or eliminate them and then you might start heading to where you want to be especially with sheet metal production runs!
One eighth of an inch gap and you think there will not be a significant amount of distortion, not to mention residual stresses afterwards???
Yeah RIGHT!!! Like I said before... GOOD LUCK!!!
Unless that is, if you're going to have some sort of set-up with heat sinks of some sort along with the appropriate fixturing yet even so, unless your application does allow for some distortion/warping, you're still gonna have quite a bit of shrinkage in some - if not all of those joints with such large gaps considering the sheet metal gauges you're working with.
Minimize or eliminate the gaps is the best course of action to take which should not be too hard to do especially if the gaps are that size, then you could use the GMAW-P welding power source package that "floats your boat - so to speak!!!" :) :) :)
