Up Topic American Welding Society Services / Certifications / AWS Aerospace code questions
- - By jonwld10 Date 09-19-2009 18:51
I have some questions regarding the AWS Aerospace code.  Are the following essential variables: Position qualified, deletion of filler metal, transfer mode for GMAW, and type of wire brushes used for cleaning base metal and in between passes?
Parent - - By Lawrence (*****) Date 09-19-2009 21:25
Welcome to the forum Jon
I guess we can assume your discussing AWS D17.1
Just provide us a bit more information.
Are you asking about procedure qualification or production restrictions??
First and most important.. You **Need** a copy of the code if you are going to qualify procedures or qualify welders for production.
In many cases D17 defers to AWS B2.1 for procedure qualification... If you have a copy of that you will find some answers.
Parent - By 803056 (*****) Date 09-20-2009 03:20
You can't meet "code" unless you have a copy by your side to refer to.
Parent - - By jonwld10 Date 09-21-2009 14:54
I understand that I need a copy to make a decision on whether our vendor is qualified to the code and currently I do not have that code right now to make such a decision.  This is for procedure qualification and I was just wondering if these are essential variables that need to be on addressed on his PQR and WPS?
Parent - By 803056 (*****) Date 09-21-2009 23:37
I don't know about the wire brush, but the rest of them look reasonable.
