Back then tank farm welds on the suction side of the pumps were not xrayed. You welded the fit up you got with a hand torch cut and sometimes that meant using up to re-bar to fill in the gap. I have seen these welds hold when the pipe yields. Especially pre 70ERW or lap welded pipe. You did not weld to code you welded to the speed the lead man wanted you to go and how backed up operations was. You can fix a lot of chit with a grinder and a good cap. Not saying it was good, just that the way it was.
If you are on heritage Exxon property that would have been Humble Pipeline.
