Up Topic American Welding Society Services / Technical Standards & Publications / Is a new PQR/WPS needed?
- - By Signeyed Date 09-24-2009 11:32
The shop where I am inspecting has a WPS for welding A 487 Gr 4 to A36.  The procedure is intended for a PJP groove weld.  The welders are currently clading the cast material using the specification's perameters, then when welding the joint they use a lower pre heat.  The shop had made a mock up using this "alternate procedure" but it is unknown what tests (if any) were done, as the quality manager is out of town.  The company has a design/engineering dept. and is taking the stand of past performance of the joint never having a failure.
My question is does 6.8 apply here or does this alternate procedure need to be qualified?
Parent - - By 803056 (*****) Date 09-27-2009 17:48
Based on the limited information provided, I would think the procedure would need to be requalified using the current technique used by production if those new parameters fall outside the ranges qualified by the original tests.
Parent - By Signeyed Date 09-28-2009 18:53
Thanks, I figured that no harm could come from testing the current procedure and having that on file.
