Up Topic Welding Industry / Technical Discussions / Gas analyser needed
- - By 2008642 (*) Date 09-25-2009 00:23
I'm needing a gas analyser. I haven't shopped yet ,but was wanting input from anyone who can steer me in the direction.  We use argon/ oxygen and argon/co2 mixes here.  Also, what would I need to detect moisture in the gas?  Do they make a piece of equipment that can do all of this?  I want something that can tell me what percentages of oxygen or CO2 I'm getting after the mixer and something that can detect if any moisture is in the gas.  Any input would be appreciated. Thanks.
Parent - - By ssbn727 (*****) Date 09-25-2009 03:29 Edited 09-25-2009 03:31
Here's what I have in one of my databases which should cover what you're looking for:
http://www.fronius.com/cps/rde/xbcr/SID-547F7FF8-685666DE/fronius_international/SGI-3_gb_Flugblatt.pdf
http://www.gesensing.com/market/ind_others.htm
http://www.thermco.com/analyzers.asp
http://www.thermco.com/ss119.asp
http://www.thermco.com/ss123.asp
http://www.thermco.com/special.asp
http://www.thermco.com/about.asp
http://www.thermco.com/article.pdf
http://gwd.weldingmag.com/mag/gwd_11511/
http://www.topac.com/sgi2.html
http://www.aii1.com/welding_port_O2_Anlzer.html
http://www.cambridge-sensotec.co.uk/products.htm
http://www.lakemonitors.com/weldshield.htm
http://laboratory-equipment.globalspec.com/Industrial-Directory/welding_gas_detection_meter
http://www.delta-f.com/pdfs/appnote11.pdf
http://www.thinksrs.com/products/UGA.htm
http://www.globalspec.com/FeaturedProducts/Detail/NovaAnalytical/Flue_Gas_Emissions_Analyzers/106169/0
http://news.thomasnet.com/fullstory/453442
http://huntingdonfusion.com/HFT/modules.php?name=Content
http://www.thefabricator.com/consumables/Consumables_Article.cfm?ID=2084
http://www.gow-mac.com/products/prod_cat.cfm?cat_id=2
http://www.eeprocess.com/STORE/item49.htm
Here's a very good article:
http://www.osti.gov/energycitations/servlets/purl/821694-kZrqDU/native/821694.pdf
Another good one also:
http://www.airgas.com/documents/pdf/eprint_airgas.pdf
Some more goods:
http://www.mksinst.com/docs/UR/onlineMGpurityds.pdf
http://www.automation.siemens.com/w1/efiles/analytics/catalogs/pa01_extracts/pa01_en/oxymat64_en.pdf
http://www.hideninc.com/gas-analysis.html
http://www.roditi.com/Equipment/Welding/Optional_equipment.htm
http://www.saespuregas.com/documents/FaciliTorr_507.pdf
Here's what a gas supplier uses:
http://www.oxarc.com/specialty_gas_production.ydev
http://www.wittgas.com/EN/home_english.html
Well that about all I've been able to come up with so far, and as I'm watching the Daily Show with Jon Stewart with the former Governor of Illinois I cannot stop laughing so, I've got leave it here!!! :) :) :)
Hope this helps ;)
Parent - By 2008642 (*) Date 09-25-2009 08:02
Thank you Henry. Once again you have been a huge help.  I must admit you are truely knowledgeable and I want to thank your for all of the info.
