OBEWAN, To give an answer to your question: We weld from 405 t0 422 to mild steel, 410 and CoMo on a regular bases with out that much preheat using mostly INCO 82 and on rare occasion 309L.
We try to use preheat but all the welding is manual with extreamly difficult access and visability (you almost have stick youre head up against the work to see or reach where you need to weld. I know what goes on when no ones is looking for I have made the same welds for many years. Crater cracks have happened but from poor pratice by the individual.
We have never had a problem with cracking with fillers other than ER410. When we must use the 410 filler we watch the preheat much closer.
One advantage to 410 is its heat risisting propertys, the heat is not so quick to travel out and dissapate so a lot of times we just wrap some insulation around finished welds.
The welds are Fillet and material thickness is from .12" to 1.+" on the Air foil where as the ring maybe any where from 3/4" to 12" max cross section.
Don't really amagine thats much help to you but thats my story and I'm sticking to it.
