Up Topic Welding Industry / Technical Discussions / Truck Driveshaft weld joint prep./filler
- - By spence Date 04-17-2002 04:14
I am setting up a motorized rotary positioner for semi-automatic welding of driveshafts , the tubing is A-513 HREW and the tubing ends are malleble cast steel . We use wall thicknesses of .134 and .180 , the joint is prepped by machining a 30 deg. bevel on both the tube and ends , the ends are pressed into the tube approx. 1 " , I prefer to leave at least .090 gap between the bevels . I am using a Miller 250 Mig with .035 hard wire
E-70s and C-25 shielding gas . Would it be better to use a dual shield wire in .035 ? I desire a finished weld with no undercut and 100% pentration, I need your ideas !
Parent - By dee (***) Date 04-20-2002 00:42
Spence,
It don't look like many of us are going to answer. Try Ed Craig at WELDREALITY.COM. Use his BBS and good luck. He will, at least, respond with his competent opinion.
Regards,
D
