Up Topic Welding Industry / General Welding Discussion / Vantage 300
- - By cdd (**) Date 09-29-2009 01:23 Edited 09-29-2009 12:13
Just bought a vantage 300. Any suggestion on where to set the arc force for running beads?( also called tha root)
Parent - By J Hall (***) Date 09-29-2009 03:52
For my taste, -2 works just right with 7018
Parent - - By leterburn (**) Date 09-29-2009 13:26
for beading I like to use a fair amount of positive force w/ mine - nearly maxed out - gives you plenty of "power" and space it a bit tight - all depends on your spacer (and if he fits it consistently) and or how you fit the joint
Parent - By cdd (**) Date 09-30-2009 00:41
Thanks for the suggestions. Ive been runnin it at about -2 from bead to cap and it welds good. Ill play with it and run up in the mid to high positive on the bead and see how it does.
