Up Topic American Welding Society Services / Technical Standards & Publications / aws d1.1 question
- By edward hinojosa Date 09-29-2009 18:12
a fabricator is going to weld a double-bevel-groove corner joint with a spacer that will also be double fillet weld reinforced. if the joint is to be welded with E7018, in the vertical position, using a 1/8 inch root face and a 45 degree groove angle,, the spacer size would be?
