Up Topic Welding Industry / General Welding Discussion / Connector plates and copes
- - By garygfc Date 10-14-2009 22:31
Attached are two drawings, one showing plate as detailed by outside detailer and other of plate as fit on column. My question, do the corners of the connector plate require a radius where the stiffner plate runs thru midway up from bottom. Ive look thru d1.1 and AISC but was unable to find and answer.
Attachment: ConnectorPlates.pdf (14k)
Parent - By swnorris (****) Date 10-15-2009 16:41
The corners where the stiffener plate passes through the connection plate are typically not radiused.
