Don't have much knowledge of super-duplex alloys. So can't speak to the gas issue.
But in the most general performance terms. Your 10mm plate will join very productively with traditional spray transfer.
GMAWP can be an exceptional value in stainless steels that are less than 1/8 inch (3mm) in thickness.. Great fusion at fillet roots compared with short circuit with no burn thru that you might see with spray.
GMAWP can also be a big advantage in out of position joining, providing spray transfer quality and good control out of position. But as Steve said.. If your work can be positioned in the flat and horizontal fillet positions... I'm hard pressed to see a production advantage to GMAWP
I just don't think pulse is necessary. And in my opinion 1.0 kj/mm seems a bit low as a max. Remember, even with supers you have to pay attention to phase balance. Duplexes are NOT austenitics. They do not have the hot crack concerns, and therfore the max heat input concerns of austenitics.
Though with supers of course you have much greater time at temp intermetallic sensitivity to be considered.
Do you have any testing regimes imposed?
I would certainly do some ferrite testing to evaluate the phase balance.
Also, when you say you have a heat inut limit of 1.0 kj/mm, what was the criteria for that number? How was it established?
I'm guessin that if your runnin 1.0 with GMAW your ferrite is gonna be high.
