Up Topic Welding Industry / General Welding Discussion / My Sa 200 idle problem
- - By Chevy_welder (*) Date 10-23-2009 22:34
have any of you guys had problems with you welder to idle slowly up it self any ideas? thanks for looking
Parent - By KSellon (****) Date 10-24-2009 16:28
solenoid spacer not in place causing plunger to drag.. Linkage binding causing drag--- butterfly shaft bent or dirty--
With the machine not running, you should be able to grab hold of the control rod (gov to carb) pop it forward (toward fuel tank) and it should snap back quickly and smoothly
Parent - - By Chevy_welder (*) Date 10-26-2009 03:57
thank you for ur respond im gonna try that ill let you know what happen
Parent - By FixaLinc (****) Date 10-26-2009 05:24
IM-179 G1 and IM-179G for R57 idlers or IM-277 for electronic.
http://content.lincolnelectric.com/pdfs/products/navigator/im/obsomenu.pdf
