I HAVE A WPS USING A FULL PEN BACKGOUGED FCAW PRE-QUALIFIED JOINT "B-U3-GF" PER FIG. 2.4. IN LIEU OF DETAILING A (0 TO 1/8") ROOT FACE I HAVE SHOWN A 1/4" ROOT FACE.
PER TABLE 5.3 (ESSENTAIL VARIABLE CHANGES) PART 30)c. "AN INCREASE IN ROOT FACE WHICH WILL NOT BE SUBSEQUENTLY REMOVED BY BACKGOUGING." I AM BACKGOUGING TO SOUND METAL , SO I BELIEVE I STILL CAN USE THE PRE QUALIFIED JOINT AND DO NOT HAVE TO RUN A JOINT DESIGN PROCEDURE. IS THIS A TRUE INTERPRETATION OF THE CODE?
CAN I DETAIL MY WELD PREP.WITH THIS 1/4" ROOT FACE?
