Metal building manufacturers fabricate beams by SAW web plate to flat bar flanges on an assembly line basis. The parts are held together in a large, adjustable, pneumatic jig during SAW with very little to no distortion, even though the beams are only welded on one side.
Here is an example of a CONRAC fully automatic machine, otherwise known as a "Pull Through" beam welder. With this machine, an operator simply feeds pre cut parts into one end and the machine spits a completed beam out the other end. This set up is rather expensive, with a basic model starting around 1 million dollars.
http://www.yodermachinery.com/machine.asp?Index=0The last company I worked for used a KENTEX semi automatic machine that worked very well but was somewhat labor intensive as operators hand load the parts into the jig and tack them together prior to turning on the automatic SAW. This macine is more economical at a starting price for a basic model around 250K.
http://www.gokentex.com/pages/beam_welding.htmHere's another link for a typical pull through beam welder.
http://www.steelexnetwork.com/beamweldingline.htmlTim
