Gonzo
You do not say what the service application is, although you mention High Torr Helium leak detection. I cannot get a "minds eye" view of the joint detail from your description. Joint geometry and cooling rate could have significant impact on joint condition following PWHT at those temperatures.
Just the AC weld alone would cause leaks on high Torr welded components. I would recommend DCSP welding withn100% Helium and at least two passes, even though the tube is only 1.8 inch thick. DCSP welds are much denser than AC welds for High Torr applications.
I would also recommend magnified visual inspection of the weld termination for crater cracks.
Joe Kane
