I have never used a purge with socket fittings. I don't see the need for it unless you are going to be getting the fitting hot enough to sugar through the heavy walls. Since the weld does not penitrate the joint, there is small chance of oxidation. I suppose if it were a very critical fitment, a purge might be an added saftey, but then you wouldn't use socket weld in a very critical application anyway.
I am not an expert and I don't play one on TV.
