Actually Jon, it is posted as: "D1 Questions" so, it's generic enough that many queries are referring to AWS D1.1, D1.2, D1.3, D1.4, D1.5, D1.6 and D1.9 with D1.8 as a seismic supplement to D1.1... This is why many queries that don't have anything to do with AWS D1.1 are posted, yet may or may not sometimes refer to one of the other "D 1" codes which I just included in the previous sentence as well as "D" letter codes or standards with higher numbers following other than the number one if you read them from left to right. ;)
I do however, agree with your point completely so maybe Ross could title it ASME as opposed to ASME Section IX because of how some provisions in ASME Section IX can in some circumstances be exempted as well as "enhanced", or the other sections may call for more stricter welding criteria or inspection criteria which is basically what I mean when I use the words: "Exempted or Enhanced" and it can be even more complex than the rather simplistic analogy which I have chosen to use in describing the intricacies and differences as well as the interaction and interweaving between each of the section found in ASME... In other words, one section can be a welding code, another could be code of construction and another one could be a code of inspection, etc.
So Ross, if you're going to add an "ASME" Section in here, then please follow Jon's suggestion because even though ASME is an acronym for the American Society of Mechanical Engineers, the very same acronym is sometimes referred to as: " Always - Sometimes - Maybe and I'll defer to Jon, Gerald or Jeff since they know it better than I do, to give the meaning of the last letter in the alternate acronym which is part of an old joke and I apologize for not being able to remember what the letter "E" represents in the joke LOL!!! :) :) :) Could you help me out here Jon, Jeff Gerald??? LMAO!!! ;) ;) ;) I think that it'll be a nice addition to the forum! ;)
