Fascinating to say the least!!!
Okay, I'll accept that, but is it an ASME governed PQR that the OP is referring to??? Not to argue with you Marty, and I understand how a computer program can rationalize it as being a 1G position with it being deposited as flat, but how can anyone who has been around welding who sits on a code committee (I'm not referring to you personally) for enough time to be able to distinguish the difference between a weld being deposited into a "G"roove ,whether it be a square, single bevel, "Vee", "J", "U", or even a flare groove, and weld being deposited on a FLAT surface with no groove whatsoever, call, or designate it as a "G"roove weld deposit??? I mean, there is really no logic behind designating it as a "1G" because of the obvious fact that the weld is not being deposited into a any type of grooved joint, or any type of joint for that matter - at all! ;)
This one is most definitely classified as a straight up FUBAR!!! :) :) :) I wonder how the AWS "D" number codes designate an overlay that is being deposited on a flat surface with no groove whatsoever as??? ;) It should be an interesting answer to say the least especially if they can come up with enough of a convincing reason as to why such an overlay can be designated as a groove weld deposit when there is no groove on the surface for the weld to coalesce into!!! Unless it's strictly an ASME response only which would then make sense if it's coming exclusively from them as they consistently remind us of their acronym's alternate definition!!! :) :) :) Hmmmmm..... Somebody really did FUBAR IMHO!!! ;) :) :)
