Up Topic Welding Industry / General Welding Discussion / CV off of Sa-200 or SA-250?
- - By phaux (***) Date 11-03-2009 02:02
Are there any add ons to have the machine put out CV?
Parent - - By tazmannusa (**) Date 11-03-2009 02:10
  Yes Lincoln has the CV adapters for those "pricey" . My SA-250 "classic II" has it and it works pretty good.
  Tom
Parent - - By phaux (***) Date 11-03-2009 02:21
Do you know if it can be taken out of the newer machines and retrofitted?
Parent - - By pipehead (***) Date 11-03-2009 02:47
How much wire feed work do you need to do? Because you can also just use a multi-weld converter... they are pricey as well but work a bit better and can be rented from Redi-arc.
Parent - - By phaux (***) Date 11-03-2009 03:04
I have a Lincoln LN-25 which I like, I just like CV output better with wire welding. The LN-25 has a selector for either CV or CC
Parent - By pipehead (***) Date 11-03-2009 03:33
Call lincoln... or bills welder repair 405-232-4799
Parent - By tazmannusa (**) Date 11-03-2009 03:27
I cant say for sure on that one, If you have the model-code from a newer SA-250 and an older one you might be able to download the manuals for both and see if the cv option has the same PN
  Tom
