Thanks for the extra info, Niekie!
Just making sure about the strain-age cracking problem. Most literature I've gleaned on gamma-prime age-hardenable alloys (including the Welding Handbook) recommends welding in the solution annealed condition for precisely that reason.
Machining before aging is a great idea! Simplifies the furnace requirement as well, since an elaborate step-down isn't needed if the part is just removed and allowed to cool in air after both steps.
I've seen that 3-stage treatment as well. The intermediate stage is to maximize carbide precipitation (Cr23C6, Cr7C3), so components operating at high temperatures don't continue to harden in service. I'm opting for the simpler 2-stage treatment (without overaging) for this reason; the valves will not see such high temperatures. (OK, plus 24 hours is not very practical! If anything we may reduce this step somewhat).
Speaking of shortening the steps, I've been revisiting my old Nusselt numbers and heat transfer equations trying to calculate exactly which soak times are required for valves of specific shape and size. "The Nimonic Alloys" (Betteridge and Heslop) documents 8hrs/24hrs/16hrs as "standard" for Nimonic 80A "bars"... but what thickness bar? Doesn't say! Ah well, wouldn't be engineering if there weren't problems...
Thanks again!
Diego
