Up Topic American Welding Society Services / AWS Learning & Education / MSc thesis title
- - By madibaa (*) Date 11-08-2009 09:26
hello friends
What MSc thesis title can you suggest for welding engineering students?
thanka alot for your helps
madibaa
Parent - By ssbn727 (*****) Date 11-08-2009 22:43 Edited 11-09-2009 04:57
Have a look at these! ;)
http://www.msm.cam.ac.uk/phase-trans/2000/phd.html
You could also get some ideas from here as well:
http://cst-www.nrl.navy.mil/lattice/
Here are some tools you can use in writing your thesis:
http://aluminium.matter.org.uk/content/html/eng/default.asp?catid=&pageid=1
http://aluminium.matter.org.uk/aluselect/default.asp
http://www.matter.org.uk/diffraction/
http://www.matter.org.uk/glossary/
http://www.matter.org.uk/solidification/
http://www.matter.org.uk/steelmatter/
http://www.steeluniversity.org/content/html/eng/default.asp?catid=1&pageid=1016899460
http://www.matter.org.uk/stereography/
http://www.matter.org.uk/tem/
http://www.matter.org.uk/authors.htm
http://www.matter.org.uk/links.htm
http://ci.nii.ac.jp/cinii/servlet/DirTop?lang=en
http://www.engineersedge.com/engineering-analysis.htm
http://www.engineersedge.com/engineering/Engineering_Downloads/Engineering_Forms_Documents/
http://www.engineersedge.com/applications-design.htm
http://www.engineersedge.com/definitions.htm
http://www.engineersedge.com/mathematics_menu.shtml
http://www.engineersedge.com/calculators.htm
http://www.bnl.gov/RHIC/
http://cdsweb.cern.ch/record/1177862
https://lasers.llnl.gov/
http://www.iter.org/mach/Pages/Tokamak.aspx
http://irfu.cea.fr/en/
http://bunter.msm.cam.ac.uk/phase-trans/2006/Kemp.thesis.pdf
http://www.hrsgdesign.com/design0.htm
http://sciencelinks.jp/component/option,com_sljlinks/Itemid,222/
http://www.msm.cam.ac.uk/phase-trans/movies.html
http://www.constructalia.com/en_EN/index.jsp
THis one isn't free, but the subscription is reasonable:
http://www.knovel.com/web/portal/browse/display?_EXT_KNOVEL_DISPLAY_bookid=776
http://watch.mit.edu/
http://ocw.mit.edu/OcwWeb/web/home/home/index.htm
https://engineering.purdue.edu/ME/
http://www.mrs.org/s_mrs/sec_subscribe.asp?CID=2986&DID=131688
http://www.engr.sjsu.edu/WofMatE/Metals&Alloys.htm
http://www.nidi.org/index.cfm/ci_id/10/la_id/1.htm
http://www.worldstainless.org/
http://www.euro-inox.org/
http://sti.srs.gov/fulltext/ms9800869/ms9800869.html
http://www.psc.edu/science/Olson/Olson.html#one
http://www.psc.edu/science/Olson/Olson-cracks.html
http://www.psc.edu/science/Olson/Olson-quench.html
https://qir.kyushu-u.ac.jp/dspace/handle/2324/12825
https://engineering.purdue.edu/BTPFL/
http://www.aluminum.org/index.htm
http://www.alcotec.com/
http://weldinghistory.org/
http://www.ssina.com/publications/sssa.html
http://www.worldstainless.org/About+stainless/The+SS+Library.htm
There's more, but I'm going to eat dinner now so this should do for now! ;)
Of course, you also have the subjects of: welding involved in various fusion energy projects such as CERN, NIL and K-Star in South Korea along with the future ITER project as well, welding technologies used in developing wind and solar energy and clean coal technology projects, welding components together for the fabrication of carbon sequestration facilities, advances in aerospace materials and joining methods, etc.,welding advanced structural materials, welding consumables developments, advanced welding processes, hybrid welding and joining processes, Post Weld Heat Treatment procedures for advanced ferrous & non-ferrous metals, etc...
There are more topics that you can choose from besides these,and you are only limited by your imagination as well as the current research out there! ;) I hope this will give you somewhere to start thinking on your own!!! :) :) :) P.S. I almost forgot about this one:
http://www.materials.ac.uk/search/result.asp?look=steel&hi=-1&acdb=tres
Parent - By HgTX (***) Date 11-09-2009 18:37
Ideally, the students should be getting guidance from their professors for what to work on.  Also they may be limited to what areas have research funding.
Hg
Parent - By G.S.Crisi (****) Date 11-10-2009 17:57
Being a College professor, I'll give you the following advice:
if you don't know exactly which MS thesis title to choose, then  first of all choose your advisor, i.e., the professor that's going to supervise your work. Ask him which would be his preferred title. May be he's thinking of starting a research work (or is already involved in one) and will take care of you in every possible manner, because you'll do a job he's interested in. A professor that's not directly interested in your work won't possibly give you as much attention.
Besides there are two other things in favor of this opinion: the first one was pointed by HgTX, i.e., the possibility of a financing of your research; the second, that your MS thesis becomes a paper presented by your advisor AND YOU before a technical conference.
Parent - - By HgTX (***) Date 11-10-2009 18:08
What's the situation?  Are they really free to pick whatever they want?  Who is funding the research?
I was given no choice whatsoever in my MS topic.  There were certain projects that had been funded, and students were assigned to different projects.  We did get to express our opinions as to which projects we'd prefer, but that was about it.
In programs like social sciences or humanities, where "research" is a thought and library exercise and doesn't involve expensive equipment or materials, it makes more sense to be asking about what a good topic would be.  I've been through that side of it too, and had a hell of a time coming up with something.  My biggest problem, though, was that I didn't know how to use my thesis advisor to help me channel my interests into a workable topic (and said advisor was not forthcoming with said help; that is why I have an MA and not a PhD, and also why I am now an engineer and not a linguist).  A good advisor will be able to tell you if your choice of topic has been done to death already, or will not be of interest, or will not have practical application, but can also show you how to pick a related topic that is still interesting, or focus your topic in a different direction than you were originally thinking, in order to get something workable.
You could look at the sources provided to see what other people have researched--but the problem there is that you see what other people have already done, so it's no longer something new for you to use.  But if you pick out a few that look interesting, your advisor should be able to use those to figure out where your interests are and what might be a good topic for you.
But if *you* are the advisor, that's a different story...part of the burden of being a faculty member is knowing the field well enough to know what makes for good research--and getting the funding for that research.
Hg
Parent - - By Metarinka (****) Date 11-11-2009 18:40
HgTX
what was did you get your masters (did you get two?) In and what was your thesis?
I'm hoping to start my masters real soon and I was partly going to shop around schools based on what their masters programs are currently doing research in. I'm not gonna go that far to get a masters in welding aluminum cans or something else boring or uninteresting
Parent - - By HgTX (***) Date 11-11-2009 21:31
My MS topic (from the University of Texas, hence the handle) involved researching alternative qualification methods for fillet welding procedures in D1.5.  Came up with some ideas, but none of it ever got implemented.
I have an MA in linguistics (specialization in semantics) which I got by dropping out of a PhD program, after which I went back to engineering school.  Five years of my life reduced to two moderately interesting lines on my resume and a talent for writing specifications.
Are there MS programs in welding engineering in the US other than Ohio State?  Or are you looking at materials, metallurgy, and other related programs?
Hg
Parent - - By Metarinka (****) Date 11-11-2009 22:53
I'm looking for something related but not welding engineering to my knowledge OSU still has the only graduate welding engineering programs, but I don't want my resume and degrees to be to narrow. I'm looking all over right now: Project management, material science, metallurgy, quality engineering, physics, statistics.
Haven't settled yet. Depends also on what I can wiggle in and how much I'll have to remediate
Parent - - By HgTX (***) Date 11-12-2009 15:58
You can't get a degree in everything (though I'm considering getting my 3rd master's at OSU...).  Sounds like you need to decide what you really want to work in.  Is your BS in welding engineering?
Hg
Parent - - By Metarinka (****) Date 11-12-2009 17:49
My B.S is in Welding Engineering Technology.
those are the fields I'm interested in enough to consider pursuing a masters in. Really I'm more interested in doing something I enjoy and will get as much out of as possible rather than being forced by an employer or job.  I love the field but having a masters in it will make me look extremely focused and narrow from a resume standpoint.
Parent - - By HgTX (***) Date 11-12-2009 17:59
A couple of thoughts.
1.  Since your degree is in engineering technology rather than engineering, you're going to have trouble (perhaps not insurmountable, but trouble nonetheless) getting a PE license.  You may want to choose your field accordingly.
2.  I don't think a master's pigeonholes anyone.  A PhD in a particularly obscure topic, yes, but a masters, not really.  Unless you consider choosing between project management and physics to be "pigeonholing", but that's rather an exaggerated viewpoint.  No one is a Renaissance man any more, and you need to decide what field would be the most fun to work in (combined with likelihood of job opportunities), pick that, and get your degree in that area.
3.  You might also consider going to work for a while, seeing if that focuses your interests more, and then getting a degree in what your work experience informs you you need more knowledge in.  Post-college work experience would look good both for your grad school applications and for future employers after you get the graduate degree.
Parent - - By Metarinka (****) Date 11-12-2009 18:24
Thanks for the pointers.  having an engineering technology degree WILL give me some trouble getting a PE license but I was never extremely interested in getting one. You need to go to an accredited engineering school of which there is only one for Welding Engineering OSU, however having a masters in an accredited engineering program will count as well; If I major in an engineering field then I won't have any problems .  If I choose an engineering masters I will have to play catch up in several core subjects in order to meet requirements. That's more a matter of time than skill.
It might not pigeonhole me but getting in a masters in Welding engineering definitely doesn't significantly broaden my skill base (just expands my technical knowledge on the subject). Also I've found that you start pricing yourself out of the market. The real killer is that I'm not a huge fan of OSU's welding engineering program... then again I was raised in Ann Arbor Michigan, so maybe I have some bias..
It's true no one is a renaissance man anymore, but I do find myself having varied interests. My father had 7 degrees: 1 PHD, 3 Masters, 2 undergrads, and one associates. To this day I never know how he did all that WHILE working.
Parent - By HgTX (***) Date 11-12-2009 19:46
There aren't many accredited MS programs.  Most programs accredit their BS rather than their MS.  From what I understand, they can only do one or the other, which doesn't make much sense to me and I haven't seen that requirement written on any ABET material, but it does explain why there are hardly any accredited MS programs.
Many states will still license you, but require extra years of experience (for example, 8 instead of 4) before you can take the test, and then you might be able to get licensed in the fussier states by comity or reciprocity.
If you're into collecting degrees, then if you have to do enough catchup you might consider getting a second BS anyway, since you might end up most of the way there by the time you're done with your catchup work.  Between the catchup work and the licensing problem, that's why I got my BS.  For a second bachelor's degree you can often negotiate your requirements and be able to use a lot of what you did for your first degree.  I did my civil engineering degree in 5 semesters (after having had 3 semesters of engineering school in a previous life that culminated in a BA).  Biggest problem is that financial aid is really hard to get for a second bachelor's.  The federal loans are still available but most other aid is not.
Parent - - By G.S.Crisi (****) Date 11-12-2009 00:10
HgTX,
You say that the ideas you developed while preparing your thesis on alternative qualification methods were never implemented. Let me ask you a question: did you show your ideas to AWS' committee dealing with welding procedures qualifications? Did you tell them the advantages of the method you envisioned? If it was impossible for you to go to AWS' headquarters personally, you could have put your comments and reasons in writing and send them to the committee.
I say this because it may be (I don't know, this is just an opinion) that the reason for not having been implemented was because you didn't give them sufficient publicity.
Parent - By HgTX (***) Date 11-12-2009 16:12 Edited 11-12-2009 16:15
My advisor and I are both tied in pretty closely to the D1.5 folks, so it wasn't a problem of access.  We never got anything implemented for a couple reasons.  For starters, we never really pushed it, and now that I've had even more experience with that committee than I did as a student, I can see how big changes are hard to get people to go for.  We had two primary recommendations that might be useful but are pretty much unimplementable.  One was for new test specimens to get fillet weld strength and toughness; the other was for the electrode manufacturers to do this testing, kind of like a standardized PQR, to set an envelope for the fabricator to operate within.  We don't have the means to get the manufacturers to do it, and we never really did push for trying to put the alternative fillet weld testing into the code.  I keep thinking there's about to be a major overhaul of Clause 5, and I stand by ready to leap in if they go there.  Any decade now.
Me, I'm in favor of SWPS and SPQR for use by the bridge code.  The PQR doesn't have to use any of the same machinery or personnel as the the production welding, so why does it have to be done by the same company?  But that would be a hard sell indeed and I haven't bothered trying to convince anyone of it.
Hg
Parent - By G.S.Crisi (****) Date 11-11-2009 23:55
Metarinka,
Suppose that while preparing your MS thesis on welding aluminum cans you discover a welding procedure (or method, if you prefer) that's 25% faster than all of the existing ones.
Two things will happen:
1. You'll render a relevant service to industry and to the engineering profession.
2. You'll sell your discovery to an aluminum can company for just 1% of the savings they'll achieve and you'll become rich.
If I were you, I wouldn't discard welding of aluminum cans so rapidly.
