Hello cwf07, you should be able to contact one of your local steel suppliers and get them to split some for you from some 16X#89 wide flange beam. That is, unless you were hoping to find some lurking in someone's yard for a reduced price. Best regards, Allan
Thanks I am trying to buy new for a job I am quoting on I checked with my local steel company 1st. they counldn't help me thank you for the help.
Have you checked IMS-Georgia Steel? 1-800-833-9175 ask for Richard. website shows what they have in stock . I don't know if stock tees but I'm sure they can cut them. www.imsgasteel.com
Thank you for the # I will check with them I called General steel & Sabel steel they couldn't help me Thank you for the time.
cwf07, Best place I have found for this type of section is Metals USA they have a cutting line set up just to do this work, never recieved "bad "pieces(cambered ,bad sizing cuts ,warped, etc.) PS. PITTSBURGH home of the 6 time SUPER BOWL CHAMPS on the hunt for #7.
Whats their #. I found some from Chapham Steel in Savannah , but the customer want it to be straight he want 1/2" in 20' the pieces are 85' long.
When we order WT's, we specify that they be split and straightened to a 1/8" in 10' tolerance. Some suppliers will stitch a beam and send it to you. Then, you have to spend shop labor to bust the stitches and straighten.
cwf07 ,The place I use is in Ambridge ,PA. but they have a Georgia division 1-800-537-1214. If they transfer you to Pittsburgh ( Ambridge division ask for a guy named Rob Wilson he always takes care of my orders with no clusters.) very hard for a salesman ! PS. GO STEELERS ON THE HUNT FOR #7.
