Up Topic Welding Industry / General Welding Discussion / Wire straighteners
- - By Metarinka (****) Date 11-11-2009 16:56
Any of you have a recommendation on wire straighteners?
got an automated GMAW unit that is blowing tolerances because the cast of the wire is causing it to wander about 0.020-0.040" to one side.
I found http://www.howarequipment.com/wire%20straighteners.htm
and http://www.toolfetch.com/p-k281.shtml
but I have no idea about reliability and build quality this thing will get used heavily in a production setting
wire diameter is 0.035 off the top of my head
Parent - By Lawrence (*****) Date 11-11-2009 18:16
Joel,
I have run into similar difficulty with Semi-auto GTAW on knife edge airseals..
MC grade wire is a good start..  also an improved feeder tip may be a possible solution.
You could give my friend Gregg at Percision Welding Technologies a message about your problem..  He is top in the world with semi-auto GTAW and Micro plasma..
http://www.pwt-online.com/
Tell him Larry B.  Says Hi.
Parent - By scottk1016 Date 08-23-2018 16:12
Metarinka,
I have had really good success with my old TAK wire straighteners.  I believe the company has changed hands, but still make the same design.  I use a #2 2-plane wire straightener.  It can be found at https://www.novoprecision.com/products/wire-straightener-bearings-and-wire-straightener-accessories/  I have also heard good things about Witels Albert and Sjogren but have no personal experience.
