Section 10. Edge Welds
Figure 46 shows the crossection for edge welds with dimensions.
Is this dimension above and beyond of the Parent Material Surface?
If it is, how does one specify the weld finish, so that there is no "positive material" above the joined surfaces?? A picture, diagram, powerpoint drawing that shows more specific than the spec would clarify the specification and the bet I have placed with the welder.
