Hi Larry!
Remember that NR 212 is a fast freeze wire much like an E 6010 - 6011 rod, so it's not going to run like the dual shielded wires which tend to mimic low hydrogen characteristics...
First question is what polarity are you using, and I ask this because it should be DC electrode negative, or straight polarity (DC-) for this wire...
What's your ESO? Are you using a nozzle on the gun? because there's no need for one with self shielded and your Electrode Stick-Out should be around an inch and a half from the contact tip at least... Are you running it in CC or CV? Also, you don't have to run it like gas shielded with respect to work or travel angle either... Are you getting enough of resistance as the wire tries to start the puddle to form? In other words, should feel a bit of a "recoil" when the wire starts to form the puddle if your Electrode Stick Out length is far enough away from the puddle as well. ;) I hope this helps a little. :)
